I have the ADVC 100 and although my VCR plays NTSC it outputs the PAL60 colour signal which means my ADVC100 gives a black and white image. Can anyone recommend a VCR in the UK which outputs a true NTSC signal???
I have seen those PAL NTSC convertors on EBay but I'm not sure I can use them because they might need a true NTSC signal in the first place and PAL60 has a different solour signal from NTSC. Also I'm worrid that such a convertor for $60 or so may degrade the signal prior to going through my ADVC100.
Any suggestions on how to capture an NTSC tape in the UK without paying a fortune for a multi format VCR would be helpful.
Franco
http://www.nexuslive.com
The UK's First Live Online Music Show
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 03:36 -
Trying To Capture NTSC VHS Video With UK Equipment
By pbar in forum Capturing and VCRReplies: 37Last Post: 21st Jul 2009, 09:59 -
NTSC Camcorder feed thru capture from PAL
By INFRATOM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th May 2009, 01:17 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum Capturing and VCRReplies: 84Last Post: 1st Jun 2008, 16:58 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 07:25
