  1. hi
    i'm trying to copy this file:- Codec: DivX 5 Bitrate: 725 Kbit/s Width: 544 Height: 304 Fps: 23.976 Audio Info: Codec: MPEG Layer 3 BitRate: 132 Kbit/s (Rounded BitRate) Channels: 2 (Stereo) Sample Rate: 48,000 Hz Miscellaneous Size (MB): 697 MB Size (kB): 713,599 KB Size (real): 730,724,988 Length: 110 minutes, 57 seconds. to pal dvd. i've followed the guide on how to change the frame rate to 25fps to the letter, but when i start the frame server it does'nt do anything.
    i've followed all the trouble shooting guides i can find but still no luck.
    I've tried versions 1.4.10 and 1.4.9.
    please help
    D-J
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    After you started the frame server, what do you do? I see you want to encode the AVI into a DVD compliant mpeg. I assume that you're using TMPGEnc as mpeg encoder.
    In this case, just select the frame server sign post file (that you've named somethingorother.vdr when starting the VDub frame server) as video source in TMPGEnc.
    /Mats
