I am having trouble converting my quicktime movies in to dvd format, the problem is that when I use the wizard I cant change the framerate to 24fps et is preset to 25fps andit wont set the aspect to 4:3 PAL.
I'm using TMPGenc, and the movies I need to convert is the ones found on www.apple.com/trailer, and they are 24fps!
Is there another program I can use that is easyer to use or am I doing this wrong![]()
Results 1 to 17 of 17
Do you have the Quicktime plugin installed?
http://www.geocities.com/SiliconValley/4942/svcd.html"Today is only yesterdays tomorrow" -
When the wizard comes up, simply cancel it. Then, click on the "load" button to load a template. Look in the "extra" folder and you should see an "unlock" template. Simply load that template up, then change the settings to the ones you desire, then save those settings as a template. Be sure and give your new template a unique name so you won't overwrite another template. The next time you open up TMPGEnc, you should be able to select your template using the wizard under "other."
Also, if you are having problems getting audio with any quicktime files, simply use this program called Rad Video Tools. It can extract the quicktime audio as a wav which can then be used in TMPGEnc. I used this program on a couple of Animatrix episodes that had no audio after encoding with TMPGEnc. Worked great! Here is the address: www.radgametools.com. -
Dear friend niko001,
I also like to watch trailers, but I have a question. Is there any possibility of saving the .mov file in that trailers you watch on the site with CLICK HERE TO PLAY thing on it ?
Thanx.
yes you can save those movies.
This is a block of text that can be added to posts you make. There is a 255 character limit -
you can use getright.
getright.com
http://cybotic.net/videoTips.html
Well just use this!
http://www.afterdawn.com/software/audio_software/audio_tools/streambox_vcr.cfm
StreamBox is good!This is a block of text that can be added to posts you make. There is a 255 character limit -
I'm having trouble getting the Hulk trailers. With Streambox or anything for that matter.Originally Posted by StealthKingWant my help? Ask here! (not via PM!)
Let me find a way to help you.
What is the site that the Hulk is on?
What programs or (techniques) have you tried?This is a block of text that can be added to posts you make. There is a 255 character limit -
I found an easy way to save them.
Once the complete trailer has finished simply right click on the middle and select "save as quicktime movie".This is a block of text that can be added to posts you make. There is a 255 character limit -
Dear friend StealthKing,
How could I save those movies ? The page is a HTML and not a .MOV. And the movie says CLICK TO PLAY. Please, explain it to me.
THANX
exactly like I told you.
after you see it right click the movie and select "save as quicktime file".
I use QuikTime PRo.This is a block of text that can be added to posts you make. There is a 255 character limit -
Try updating it also.
Dear friend,
I don´t have the registered version of Quicktime Pro. Should I buy it then ? Is there a "Free" way to get those trailers ?
Thanx again and I really don´t want to bother you, I´m just a newbie.
Email me at StealthKing123@hotmail.com
Your Welcome.
o001-To convert quicktime to DVD I would use EO Video to convert the Quicktime movie to DivX and then use TMPGEnc to convert The DivX to DVD.This is a block of text that can be added to posts you make. There is a 255 character limit
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 16:31 -
dvd to mov
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2010, 18:00 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
MOV to DVD
By darogo in forum ffmpegX general discussionReplies: 9Last Post: 26th Apr 2008, 12:09
