Simple question: Does anybody know where I can get the MPEG 2 encoder which comes with DVD Studio Pro? I just want to encode MPEG2s, and I don't want to spend lots of money for DVD Studio. I would buy the codec, but it is not available as a standalone product, so sadly I have to search a warez version of it. It's basically just a plugin you place in the Quicktime Extensions folder in your System Extensions and then you can use the MPEG2 Codec in the export option from Quicktime and Final Cut. Any location besides Hotline where I could get it? Somebody willing to mail it to me?
uw@xweb.de
I am not positive, but I believe that it is inlcluded with QuickTime Pro, cost 29.95.
Sadly, not. QT5 has full MPEG 1 support. MPEG 2 support was planned, but to expensive. They later bought the company "Astarte", and since then, they have their own MPEG 2 codec (I have it now btw.) which they use in iDVD and DVDSP. QT 6 will support MPEG 2 AND MPEG 4
I just can't await it...QT 6 will be great!
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Need Windows streaming encoder for Quicktime/Darwin streaming server?
By The village idiot in forum Video Streaming DownloadingReplies: 0Last Post: 10th Feb 2012, 14:50 -
The best Quicktime H264 encoder?
By totalfreedom in forum Video ConversionReplies: 14Last Post: 11th May 2009, 12:31 -
How to use the Quicktime MPEG-2 component
By tealgrey in forum MacReplies: 5Last Post: 10th Mar 2009, 16:30 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51
