I use SVCD2DVDMPG and author the files with Tmpgenc DVD Author, but the audio is not in sync. I tried to use Scenarist, but then I get this error message, when I import the video file: Number of pictures (20) in GOP(# 4550) or between sequence_header_code should be equal or smaller than 18.
I want to author tv shows I have as VCD.
Results 1 to 10 of 10
fdmGuest
What i learned so far form my numours tries to make dvds out of VCDs is:
1. Always use a two step encoding form mp2 to ac3. mp2->wav, wav-ac3. Or even 3 steps: mp2->wav, wav 44.1 - > wav 48, wav->ac3. This gives less cracking in the audio. And if this doesn't help try the solution of tip 2.
2. Sometimes audio is out of sync. Then reencoded the audio with tpgmenc. then encoded it to ac3 it will be sync than. This is the problem i have for 90% of the time.
3. Use a program to author the dvds that doesn't reencoded the input files like: SVCD2MPGDVD+ but that will not work if you got the second problem or tmpgenc dvd author. I know you can't have fancy menus but it is always better then video's with blocks or audio trouble. -
fdmGuest
I will try it.
Do you have an idea, why I cannot import the m1v file into Scenarist? -
some of the high end authoring not only look at resolution but also GOP (Group Of Pictures) number to determine DVD SPEC compliancy....
Ones i know if are DVD Architect & ReelDVDSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guest
I still have sync problems.
Has anyone an idea?
Has anyone experience with authoring vcd on dvd downloaded from the net? -
I have tried many times and i only had troubles with the video to get it right. Audio also gave troubles but never after the steps i told you before.
Can you tell me what methode you are using now.
Yf -
Also have a look at this:
https://www.videohelp.com/forum/viewtopic.php?t=161658&start=0&postdays=0&postorder=asc&highlight=
Are your sources TVRips with the adverts edited out......SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
fdmGuest
@ yf2001usa: I tried it your way and used for authoring ifoedit and tmpg dvd author. With Both I had the problem.
@ ChrissyBoy: I try the way DVDMixer describes. Sounds promising.
Btw thank you both for the help. I appreciate it. -
You can try that but don't get your hopes up.. that is the way i do it too. Only i don't reencoded the whole ep, just the sound.
Yf
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
