hey
i was wondering if there is an mpeg splitter out there that can split all the way to the frame, rather than the second. i am trying to do some cutting, which of course QT wont let me do, so i need a splitter that can let me cut exactly to the frame. lemme know if u know of one, or if u know of an easier way to do this. thanks.
-Tolly
Editing Mpeg is notoriously difficult because you cannot cut at any frame, only at the I-frame, which is a stand-alone image. The other frames are incomplete images defined by their relation to an I-frame.
In the PC world, there is one mpeg editing program, Mpeg-VCR. I do not know if a Mac version is available. -
Although I havent used it, I have read that Mac users have success with editing Mpegs with the visual cutter found (press option key) in MPEG CUTTER part the Gumby Application set
http://gumby.misplacedmac.com/
hth
Best freeware MPEG-2 splitter?
By ANOther1676 in forum EditingReplies: 26Last Post: 4th Feb 2011, 15:59 -
Haali MPEG (PS) Splitter
By zawmn83 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2010, 23:33 -
MPEG-2 Splitter for MPC
By cheerful in forum Software PlayingReplies: 19Last Post: 22nd Sep 2009, 23:15 -
MPEG Splitter
By Amanaman in forum Newbie / General discussionsReplies: 12Last Post: 5th Sep 2009, 15:28 -
MPEG-2 Splitter?
By therock003 in forum Software PlayingReplies: 1Last Post: 22nd Jul 2008, 11:24
