Help debugging a SVCD issue...
I downloaded a certain movie about clown fish in BIN format. Actually SVCD format. When I play the SVCD on my DVD, the resolution looks very low. Almost as if the film is playing at half the real resolution.
If I extract the MPEG from the BIN and play in on my computer, the resolution looks fine. I also tried taking that MPEG and recreating a SVCD using nero. But when I play that SVCD, it also appears to be lower resolution.
A quick way to tell is the X in the PIXAR logo at the start of the movie. On the computer it looks smooth, and on the DVD player it looks jagged. And it is NOT due to the resolution difference between the computer and the TV.
I also used another method to play the MPEG directly on the TV (using QCAST) and the resolution looks fine.
Reading the MPEG into virtual_dub, the resolution is stated as
(480x576), 2 = (4:3)
Any tips on what the cause of this is? Something in the SVCD flags?
Thanks,
Dubya
Results 1 to 1 of 1
Converting HD (1280x720) to lower resolution for YouTube
By arjanpublishing in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 31st Dec 2009, 11:17 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 14:25 -
Frame resolution is suddenly much lower when capturing?
By dimitri_vdh in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 16:48 -
Bigger file with lower resolution after conversion???
By unplug in forum EditingReplies: 6Last Post: 20th Aug 2008, 16:09 -
High Resolution Playback Blocked
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 4th Mar 2008, 07:38
