On Winamp my mpeg2s get played with black screen and audio only, while they work correctly on media player.
On both players they get played with a wrong height/length, theyre always too high in the ratio. I read that I could solve this by using a different mpeg2 codec, but I dunno which one I should take then.
Hmm, Id like to use Winamp if possible, cause its faster than the other stuff. But do PDVD or WDVD have a codec that would make Winamp play it correctly?
yes -- but i have no idea if winamp will play it in the correct aspect ratio..
it WILL be played in the correct aspect ratio in powerdvd or windvd
USB AVCHD for ps3 doesnt work
By caner12 in forum Video ConversionReplies: 2Last Post: 10th Aug 2009, 15:28 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 6th Mar 2009, 23:46 -
get smart doesnt work with DVD Fab
By shoesss in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 11:52 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 09:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 10:21
