my movie has jay leno vision. how do i fix that with a free tool like virtualdub or avisynth.
What is Jay Leno vision?
hmmm. how do i explain it? imagine that these brackets [ ] are one frame of video. imagine there's a face in those brackets represaented here by forward and backslashes: [/ \], or in my case [\ /]
If you are familiar with Adobe Premiere, you can use "distortion" and it may fix your clip.
In Premiere 5.5 (yeah it's a little old) it's found in the Clip menu. Have your clip selected in the timeline (the 'marching ants' marquee should be surrounding it). Go to the Clip menu, then Video and then Motion. In this window the upper portion controls movement for your clip and the bottom part controls distortion, rotation and zoom. You can use the distortion operation to correct the bad angle of your clip by dragging on the corners of the image. Make sure to set the Start and End of the Motion part of the window to center so that no real movement will occur (select the Start position and press the Center button, select the End position and press the Center button). This does have limitations (you can pull out the corners only so much). Re-render your clip and you're done.
Hope that helps. Good luckHappy to be here.
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 11:59 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 08:11 -
Fixing bad PAL->NTSC conversion
By Goldmonkey2828 in forum Video ConversionReplies: 1Last Post: 30th Aug 2007, 20:40
