Hello. I've been doing a lot of reading and working with several programs to try and make this work but so far I've been unsuccessful.
Out company has 7 of our best TV 30sec commercials that we want to put on one DVD for presentation. Three of the ads are on one DVD, thee on another, and one alone. I've tried ripping them off with DVD Decrypter then adding them as an asset to DVDLab (Demux) and then burning them to DVD-R's. All the video is great but I get no audio? In DVD lab it shows the audio as AC3 but I get no audio from the final product. I've tried burning it with Nero and no audio. I like DVDLab because of the flexibility of the menu creations but without sound that doesn't do me much good.
Am I doing something wrong or is there a more sure way of getting the objective of 7 clips off of DVD's and moving them to one DVD with a menu? Thanks.
Todd
The procedure you have used is sound (no pun intended) so far as I can tell, but I am not a DVD Lab user (yet).
You may want to check the AC3 files to make sure they have ripped OK (eg. if you have a AC3 codec installed you can just play in Media player).The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
But the problem is that for some reason when I burn to DVD there is no sound on the DVD? This is baffling.
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
how to prepare Youtube Vids?
By 3thman in forum Video Streaming DownloadingReplies: 6Last Post: 8th Dec 2009, 12:11 -
Help with loading vids pls!!
By lona in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Jun 2009, 14:44 -
Saving U Tube Vids
By skybird in forum Newbie / General discussionsReplies: 5Last Post: 16th Oct 2007, 20:25 -
Cutting Vids Help
By nldnboi in forum EditingReplies: 1Last Post: 2nd Oct 2007, 21:12
