hi, just like the subject says
i need something simple that will only join, no more.
thanks.
y would u want to join wmv? it is a horrible format. but u could use windows movie maker, although it reencodes them i think. dont bother with wmv
Windows Media Encoder is Microsoft's free program for encoding its Media formats. It comes with a free utility called Windows Media Editor, which will cut and merge. Go to the Microsoft Website and search under Windows Media.
Windows Media Encoder and accompanying utilities are very comprehensive encoding programs, with extensive setting selections (including 2-pass variable bit rate encoding, and DV capturing.) The only problem with them is that the final result is ... Windows Media files.
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
best programs to join wmv from command line
By ziptip in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2008, 01:02 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 22:58 -
how can i join VC-1(WMV-3)files
By sumeshkri in forum Video ConversionReplies: 3Last Post: 26th Oct 2008, 00:21 -
Is there a way to join or merge WMV files?
By srauch in forum EditingReplies: 4Last Post: 8th Sep 2007, 16:39
