im burning a dvd, my source is PAL (25fps) and i dont think its necessary to change it to NTSC since most player will play both anyways, right?
well my real question is should i have the resolution be PAL standard if the framerate is, or does this not matter either? what do you reccommend i do? thanks.
-Tolly
Hey.. I'm a pc guy so i don't know if this will apply to you, but i just converted my first PAL dvd to NTSC dvd and on a pc, let me tell you, it is a pain in the arse.
Looks like you're in the U.S.--so am i.. Finding a dvd player to play PAL is not the problem i don''t think--it's finding a TV in the U.S. that can play PAL (25fps).
I had to demux original PAL movie into audio/video, convert fps from 25 to 23.97, re-encode the video, run 3:2 pulldown to convert to 29.97fps and finally remux/reauthor and burn.. whew.. Again, i'm not familiar at all with mac, but i would think it'd be the same process.. Oh, and then i had to stretch' the audio from 25fps to 29.97fps, using BeSweet
Here's a recent thread that is very in depth:
https://www.videohelp.com/forum/viewtopic.php?t=160433&highlight=pal+ntsc
Hope i didn't provide any misinformation---i'm relatively new to this -
I'm actually in need of some help. I am trying to convert a PAL DVD to NTSC DVD.
Right now I have all the files on my harddrive under the "VIDEO_TS" folder. Is there a program for the mac (not pc) that will help me convert the movie to NTSC without having to drop it down to avi or mpeg first? -
Here's my solution... I found a cheap chinese dvd player (Sampo) that does the pal to ntsc conversion on the fly. I was going to make a ntsc dvd by hooking it up to my standalone dvd recorder, but since I already had the disc and a player that would play it I decided to just use the pal disc.
The next time any of my friends gets one though, I'm ready!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
