I hav the plus version of the program and it works great
Problem 1
But using a router and its firewall function - everytime i try to upgrade from the menu, the program closes and I'm told that I'm not connected to the internet.
Anyone solved this problem or know a away around it?
I've spoken to Badger and its suppose to update through port 80 http.
I've tried updating with IE running but i get the same result - help.
Problem 2
Anyone produced any guides for the menu yet?
I did 2 movies with the menu - which just closed after editing the names.
After the conversion - the dvd folders were missing video_ts.BUP file?? when i try to burn with nero
The files i get are:
video_ts.IFO
vts_01_0.BUP
vts_01_0.IFO
vts..01...vob
vts_02_0.BUP
vts_02_0.IFO
vts_02...vob
Help
Problems 1:
People with proxies/firewalls are having an issue with the update functionality. To that end i've set up a mechanism for manual updates:
http://www.svcd2dvdmpg.com/SVCD2DVDMPG/AutoUpdate/GetUpdates.aspxSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Update on ATI TV Wonder 650 USB Auto Gain Control (AGC) Issue
By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 22nd Aug 2013, 09:39 -
DVD menu exists in video ts folder but won't auto play upon insertion
By perceptionist in forum Authoring (DVD)Replies: 3Last Post: 2nd Aug 2009, 05:13 -
How many firewalls should we used ?
By SingSing in forum Newbie / General discussionsReplies: 12Last Post: 3rd Jul 2009, 10:50 -
Question about McAfee auto update
By jimdagys in forum ComputerReplies: 3Last Post: 18th May 2009, 09:40 -
Auto-choice in Menu
By Corey in forum Authoring (DVD)Replies: 1Last Post: 1st Dec 2007, 16:19
