Why is vcdeasy copying my mpeg file to cd as a dat file? Is it me that's doing something wrong or is it the program? After I've ripped the file from the dvd and changed it to an mpeg I can view it on the computer just fine. But when I burn it to the cd it transforms it to a dat file.....can I be helped or am I a lost cause.![]()
when vcdeasy burns a cd, it first makes an image of the cd it is going to burn, then it burns the image. this is normal, its just what vcdeasy does. if u want to make a copy of the vcd u just burned, u can keep the image it makes and just burn the image instead of copying the disc. u can delete the image after it is done burning, there is no need to keep it unless u really want to, and dont worry about the fact that it is making it, if the vcd works, who cares?
it should be a dat...otherwise I dont think it would play in a dvd player. I beleive the dat file is just a container for the mpg and some extra info needed for standalone dvd players to play them properly.
This is indeed normal. The White Book standard, which specifies the data and directory structures for the VideoCD format, requires that the file be named with a .DAT extension. (Note that White Book was, if memory serves, defined by Philips before MPEG files were in common use on personal-computer platforms, so they wouldn't have had any reason to use the now-common MPG extension. Also, a White-Book VCD .DAT file differs somewhat in structure, since it does indeed contain some data structures specifically designed to be useful to a standalone VCD player.) Therefore, when VCDEasy creates a VideoCD out of your MPEG files, it's going to add those data structures and convert it to a White Book-compliant .DAT file, so it can make a White Book-compliant VCD.
If you just want to save the MPEG-1 file to a CD-R _without_ creating a VCD, use Nero and burn as a data disc, rather than a VCD. (Note, though, that you might not be able to fit the whole file on a data disc, depending on how big it is -- White Book VCD squeezes extra capacity out of the disc by using the space normally reserved for error-correction codes as data space instead.) -
sorry, i didnt realize u ment ON the disc there was a dat file, i thought u were reffering to the bin and cue files vcdeasy generates. but anyway, it is just a way of getting the standalone dvd player to read it.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
Help a newbie with BR burning... please.... :)
By mefistofel_666 in forum DVD & Blu-ray WritersReplies: 8Last Post: 3rd Dec 2009, 16:11 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
