    Sep 2001
    sweden
    Hi got a prob... have some div-x movies with Ac3 audio and i cant manage to extract the audio from them so i can re-encode them as vcd in tmpgenc.... anyone know how to extract the ac3 sound so i can convert it to stereo??
    Sep 2001
    sweden
    I have tried to rip the audio with Virtual dub but it only says that it cant find the file and i have tried to encode it with nero but then i got the audio out of sync....there must be some other way to do it.....
  3. Use Nandub or the AC3 version of Virtualdub, the regular version of Virtualdub can't read AC3 files.
    Sep 2001
    sweden
    I have the lastest version of virtual dub with ac3 but it doesnt work....ill try with nandub...
    Sep 2001
    sweden
    I have tried nandub and it seems like it extract the sound but i doesnt seem to convert it from ac3 to wav....i have tried with everything and finaly i got ac3 decoder v 1.0 to convert it to stereo but it only converts half the sound file....why??? is there any restriction with the prog when itīs not registered???? is there any other good prog to decode the ac3 sound to stereo??
