i'm new to most of this stuff. i burned some movies i made onto a dvd-r using idvd2. they were in .mov format. i was wondering how i could copy these back into the computer into an mpeg or avi format. i have a pc for different converting programs, but i only have a dvd drive on my imac.
well your options are endless really. One application you should get is ffmpegx. Since you said "I have a pc for differnet converting programs" but your dvd drive is on yoru iMac its best to stay in the computer your data will be on. There is nothing fancy or PC only apps needed to do what you need to do.Originally Posted by karc
With ffmpegx, you can simply select your .vob files individually and convert them into the two options you want (mpeg and .avi)
I woudl suggest downloading the program and also visiting the recently renovated ffmpegx home page which has some great pictures and explanations of each of the options avaliable on the program.
Here's the webpage
http://homepage.mac.com/major4/
Likewise, if you look on the left portion of the page, you can find
VIDEO_TS to DivX link which will explain step by step what you need to do for VIDEO_TS (which is DVDr to avi (divx)
enjoy
Multiple avi movies on one dvd......portable dvd player that plays it?
By 9tinyfingaz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Jul 2009, 04:56 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
5 Avi Movies to Dvd - Easiest Way Please?
By Ruudboy in forum Video ConversionReplies: 14Last Post: 23rd Nov 2008, 21:39 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 21:11 -
Converted analog film movies to BMP/JPG: now to AVI and then DVD
By Wimpie44 in forum Newbie / General discussionsReplies: 13Last Post: 1st Jul 2007, 13:47
