  1. like TV episode (mpeg1) and even create a small menu for choosing which chapter to play? it is possible?
  2. Human j1d10t's Avatar
    Feb 2003
    California, USA
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  3. definetely. You'll want to use a DVD authoring tool like Movie Factory 2 and if they are mpeg 1, you'll need to up the aduo bitrate. Baldrick has a great guide on how to take mpeg 1 movies and convert them using MF2.
  4. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    It is really easy and possible.
    TMPGenc Author can do this with no problem
  5. The easy way to do this is with (S)VCD2DVDMPG. Take a look at this guides:
    All-In-One guide, VCD or SVCD to DVDR/W with SVCD2DVDMPG+
    SVCD2DVDMPG+: How to get started
    Finally !! A ((SUREFIRE)) WAY TO PUT MULTIPLE VCD'S ON A DVD
    The last link will make you do the most work, but it gets every ep on a dvd.
    Yf
