I currently have a FlyVideo 3000 (which is going back to the place it came from on Sunday) and I am asking you guys what you think is a decent capture card for under 100 Pounds (sterling approx $160)
I want it for 2 reasons
1.Capturing footage of my 8mm Camcorder to create Dvd's
2.To record the ocasional Boxing match e.t.c to enojoy at a later date.
I would appreciate any sugjestions as I F##ked up when I bought this one so I'm not gonna make the same mistake again.
What do you think about Hauppauge? are they good or over rated?
Pirate Prince...............Over and out.
WinTV-PVR 250 is your best beat for record ture DVD that 720x576 in REALtime MPEG2 at any biterate you want fell free stop by SHSPVR forum ask any thing you like.
WinTV-PVR 250 or 350 dazzle 2 pci card is good but go to www.dazzlegeek.com to see if it works with your mother board ATI AIW is oh ok if you get one cheep
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 13:56 -
A "good enough" capture VCR for under $100?
By ministry88 in forum RestorationReplies: 1Last Post: 6th Mar 2009, 00:13 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Can I use a capture card if my TV does not have a "TV Out" signal
By jthompson99 in forum Capturing and VCRReplies: 7Last Post: 13th Jul 2008, 21:50
