I used the DIVX program you can find in the tools section. I was able to copy a DVD but I was unable to create a VCD from the file. I set the Divx program to create a VCD. I then created 2 volumes using the chapters under the output option. After creating the .mpg file I was able to view the file on the PC. I burned the CD using Easy CD Creator. I am unable to view this CD on my DVD player. But when I create VCD using TMPGEnc after capturing from VCR using Multimedia Center from ATI I have no problems viewing.![]()
Do you know if your standalone supports VCD? Also, is the VCD MPEG that wouldn't play in your standalone VCD compliant (within specification for VCD)? What resolution, bitrate, and MPEG type is it (mpeg1/mpeg2)?
Impossible to see the future is. The Dark Side clouds everything... -
Thanks for the fast response. My dvd player can support VCD. The file was mpg1 1150 bitrate, resolution 352 x 240. I have used this same setting everytime I created VCD's with TMPGEnc.
What about the framerate of the MPEG, and the audio bitrate? Use MPEG Properties or AVI Codec in the TOOLS section to verify your mpeg's properties.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 04:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01
