has anyone tried creating an svcd from a backup dvd-r that was run through DTOX? Just wondering if the quality and file sizes would be the same (or nearly the same) as the original?
Originally Posted by square
Forty-Two didnt work since it didnt like the dvd-r movie only copy.
SO i had to demux the .vob, reencode the mpeg2 convert audio to .mp2 at 128k/sec with 44khz remux and author as svcd, but yea it works and looks pretty decent
but if you are goign to do all this, why not just use the DVD instead of the dvd-r, you will probably get better results. -
i was mainly concerned with whether or not the file sizes would be smaller ripping from the dvd-r. it seems that the file size outputted from forty-two goes along with the size of the movie it pulls of the disc (more so than the length of the movie). so...with a disc the has been run through DTOX obviously having a smaller file size than the original, it would be my guess that the svcd files would be smaller than running it off the original disc.
i haven't done this and don't even know if i plan to...i was just curious. -
I didnt end up using forty two since it didnt accept the dvd-r.
I just demuzed each of the .vob files, converted the .m2v to 2500k/sec and remuxed the audio after converting from .ac3 to .mp2
it was standard SVCD file size.
hope that fills your curiosity
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 08:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 00:50 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 15:55 -
Help with DVD Backup
By zeroplace in forum DVD RippingReplies: 3Last Post: 23rd Jun 2008, 09:48 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 08:38
