Hello people i have got a problem. I have a dvd with only songs on it. I used Dvdbackup to rip the dvd. And Used dvd2oneX to make the dvd to 4.4 gb So I could use toast to burn it. But the strange thing happend after i draged the vob files to the toast it gives that it is 4.5 gb instead the 4.4gb I had chosen . I have tried this 3 times to get 7.2 gb to 4.3/4.2/4gb but ervery time it gives 4.5 gb if I put in the toast to burn(((.
Do I something wrong???????![]()
Just a little wondering, but you might try making the target size 4272 MB instead of 4372. Since it seemds to be a 100 megs over.
If that was the problem than it was solved but I have tried 3 time first from 7.2 to 4.4 than to 4.3 and 4gb but ervery time it the same 4.5gb.
Its weird but no
try running the 4.5 gig dvd again with DVD2ONE might take off the last 100meg's give it a shot
Maybe dvd2one doesnt handle audio files as good as video...
While experimenting one time I tried to compress a DVD to the size of 700MB - call me crazy but hey -
The DVD itself was about 6 GB with Video and 1 AC3 channel. After DVD2one was done - the outcome was 1 GB - I think DVD2one does nothing with the AC3 because thats already compressed and after reading your problem I think your problem has something to do with that.
These audio files of yours - can you post what format they are? -
DVD2OneX does not compress the audio, only video. It won't change the size of any audio files, other than deleting unwanted ones when told to do so.
Others have reported success with the technique of reprocessing a compressed DTOX DVD when the compressed files are greater than 4.4 GB on the first go. -
About using Dvd2oneX I used it workt well but now the piont is that it seems that the video has lost quality. It has compressed the movie So not a good
to use dvd2one again bad luck someone other
DVDR vs 2GB BDrip
By Vyoam in forum DVD RippingReplies: 29Last Post: 6th Jan 2013, 16:26 -
Any experience with WD My Book Essential 2gb?
By sohaibrazzaq in forum ComputerReplies: 3Last Post: 26th Sep 2011, 10:21 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Shrink DVD to 2GB or Less
By pandemonium in forum DVD RippingReplies: 18Last Post: 7th Nov 2009, 01:34 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20
