i have a problem with the audio not in sync about half way through the file atfer it is encoded there is a big glitch then the audio goes out of sync the avi is 512x384, 64950 frames, 25.000 frames/sec 136kb sec i put it on ntsc ,non interlace progressive ,tried both feilds ,16.6 then save it to a different place than the orginal file then i start after it is done picture is fine but u can see a slight jerks on the video the audio sounds great but half way through lose there is a big glitch then audio goes out of sync i have done to others and they turned out fine have problems with this one need help anyone![]()
read up on video formats. 25fps is a PAL framerate, not an NTSC one.
2,
read the guides. they will all tell you to process audio seperately from .AVI files. -
Glitches need to be removed, use Virtualdub to scan and remove bad frames, check in the guides.
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 20:42 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 07:05 -
Problem converting MKV / MPG to DVD.
By smackyourfupa in forum Video ConversionReplies: 6Last Post: 24th Jan 2010, 04:55 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 04:30 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 22:13
