i have a DVD bought from abroad and i want to add my own language subtitles...how can i do that?
D/load MaestroSBT (http://www.doom9.org) it will convert the SSA script file into a series of BMP files with a timed text file. However, the only authoring programs I know of that allow you to import subtitles are: DVD Maestro (which I use), scenartist, and Reel DVD.
So unless you have one of those programs you might be out of luck.
Basically what you need to do is re-author the DVD with the added subtitle track. Prehaps theres some way to just 'mux' the subs into the existing VOB files (IFOEdit?) but I don't know how/of a way to do this. -
thanks ,
i do have all the above programs...what i sthe best to use?
or should i say the easy one?
after re-author i want to keep the original menu and all it can be done right? -
DVDMaestro cannot load my m2v file to the timeline...
it says the movie lenght is to long (1:40min)? why?what am i doing wrong?
Adding SSA subtitles to MP4 files
By ngngokkiu in forum SubtitleReplies: 19Last Post: 21st Feb 2012, 06:24 -
explorer.exe high memory usage while trying to load ass/ssa subtitles
By Nightroad in forum SubtitleReplies: 2Last Post: 17th Jan 2012, 18:36 -
Tool to convert SRT/SSA to Sony DVD Architect subtitles ?
By miguelos_net in forum SubtitleReplies: 4Last Post: 4th Dec 2011, 21:48 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
Add subtitles to DVD using DVDSubEdit
By marco_silva85 in forum SubtitleReplies: 3Last Post: 19th Jun 2008, 22:57
