Hi, I am attempting to author an SVCD that has 3 parts(mpegs) and this is as far as it goes:
Starting (S)VCD2DVDMPG+: v1.0.1241.36185
Begin time: 1:24:06 AM
############### New MPEG File ###############
File: E:\folder\file1_02.mpg
Horizontal Res: 480
Audio SampleRate: 44100
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
******** Multipexing elementry streams
From this point no DOS window pops up. I am able to start over or close the program, but the same thing happens. Also, I have not changed any config settings. Thanx in advance for the help.
Guest
Actually I've seen this a bit. It happens for one of two reasons:
1. MPlex doesn't like the files, for any of a number of reasons... USUALLY related to a "padding" stream that has been included in a number of SVCD's lately.
2. There's a missing audio stream... because BeSweet didn't finish properly or something like that. If Mplex doesn't have BOTH input streams, it'll hang/crash and the whole process will just go belly-up.
- Gurm -
BeSweet version please?
just install the requested besweet version 1.5b17 or 1.5b18 that will do the trick i know out of experience..
Guest
yessssirrrrrr. thanx for the help guys, I had to update my besweet. I have authored 2 dvds from (s)vcd so far! You rock!
stuck for a program to join mpg's without reencoding
By orbspider in forum EditingReplies: 12Last Post: 8th Dec 2011, 11:57 -
Basic question on MPEG-2 multiplexing
By nharikrishna in forum Authoring (DVD)Replies: 7Last Post: 2nd Feb 2011, 23:32 -
TS / MPEG test program
By khcon in forum Video ConversionReplies: 7Last Post: 19th Jan 2010, 12:15 -
multiplexing two files ? whats the best program
By just in forum Newbie / General discussionsReplies: 3Last Post: 22nd Oct 2008, 12:47 -
HDTV to MPEG 2 Program
By christopheramos in forum DVB / IPTVReplies: 8Last Post: 9th Mar 2008, 10:39
