    Jan 2003
    I hope someone can point me in the right direction. I am trying to find a template or measurements to print out a DVD cover. Not the same old DVD cover but one for a triple disc case. Its thicker so the regular cover is a bit short. If any one can help it would be appreciated.
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    what program are you using to do it?
    if you do a Google search for "dvd template" you should be able to find a bunch - most commonly templates for Quark, Illustrator or Photoshop.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Jan 2003
    What I usually use is Photoshop. I have the right measurements for the basic dvd case but when I try to mess with it and make it bigger it messes up the pixels. I will search on that. Thanks.
    Jan 2003
    After searching, I still can't find a template for a 3 disc dvd case. Again its a thicker type of case. Exact same that came with the Back to the Future set. Any one else have any idea?
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    take one of the one or 2 disc Photoshop templates, and increase the size of the spine.
    This is one of those times when a ruler will come in handy.
    - housepig
    Housepig Records
    out now:
