Using Adaptec Easy VCD creator(4.x) I used to create VCDs where u can have like 2 or 3 play sequences. Let me explain what I used to do.
I got like 9 different MPEG files (Say 001 - 009). I group them into 3 sub Categories
Group -1 -- 001, 004, 007
Group -2 -- 002, 005, 008
Group -3 -- 003, 006, 009
Then create a Menu choices as
1. Play ALL
2. Play Group 1
3. Play Group 2
4. Play Group 3
Choice "1" would play all in sequence 001, 002 ,003.. 009
Choice "2" would play 001,004,007 ONLY - at end return to main menu or just stop
Choice "3" would play 002,005,008 ONLY - at end return to main menu or just stop
Choice "4" would play 003,006,009 ONLY- at end return to main menu or just stop
It was easy to add since we just define play sequence and drag and drop.
Now how do I achieve the same using VCDEasy?
Using the interactive section I can define where to go in the menu.
But how do I define what is the next sequence for that choice?
Typically these are different file (so separate tracks), but I can join all these and define as chapter entry points if that is required.
Hope I am clear ..
I am unable to use Adaptec (Roxio) VCD 4.x now because that does not support my newer DVD/CDRW combo. If I create a image, I could not get Nero (which is what I am using now) to read/burn that file!
Any help is greatly appreciated.
If not VCDEasy, any other tools that can achieve this task?
This type of multi-title playlist (which I've discussed in previous posts) isn't best done with VCDEasy. To get it exaclty the way you want it (and it CAN be done nicely), you should edit the text of the VCDImager XML by hand and burn after editing.
If you want you can start with VCDEasy doing a simple 4-selection disc and then save the XML for later editing. This might speed up the process-or maybe not. For more info read Vitualis' VCDImager Guides.
HTH,
I don't want to hold your hand too much 'cuz it sinks in better to do it yourself, but have a look at one of my previous posts on the subject. It goes into very much the same thing.
What I'd do in VCDEasy would be to add all the clips, create menu selections for the 1st clip within each series.
Example:
[Menu]
Selection1=Movie001(will be "PlayALL")
Selection2=Movie001(will be "PlaySeries1")
Selection3=Movie004(will be "PlaySeries2")
Selection4=Movie007(will be "PlaySeries3")
Make the end of each selection return to the menu.
In the XML, change the code from:
[selection1]
playref=movie001
nextref=menu
[selection2]
playref=movie001
nextref=menu
[selection3]
playref=movie004
nextref=menu
[selection4]
playref=movie007
nextref=menu
...Changed to include the other movies like so:
[selection1]
playref=movie001
playref=movie002
playref=movie003
playref=movie004
playref=movie005
playref=movie006
playref=movie007
playref=movie008
playref=movie009
nextref=menu
[selection2]
playref=movie001
playref=movie002
playref=movie003
nextref=menu
[selection3]
playref=movie004
playref=movie005
playref=movie006
nextref=menu
[selection4]
playref=movie007
playref=movie008
playref=movie009
nextref=menu
Or something like that.
You may want to change the previous, next, and defaults depending on which playlist you're in, or override the default numbering so that all clips are available as selections (in order) at all times.
HTH,
howto play Uncompressed RGB (AVI)
By kamaldeepdung in forum Video ConversionReplies: 33Last Post: 7th Jan 2012, 16:19 -
HowTo make Virtualdub as portable as possible? (without using VdubPortabl)
By KneeRow in forum EditingReplies: 7Last Post: 19th Apr 2010, 12:52 -
Howto Blueray to DVD, then play on HD DVD
By MickeyMouse in forum Authoring (Blu-ray)Replies: 5Last Post: 2nd May 2008, 10:45 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13 -
trouble with secondary color
By kay in forum SubtitleReplies: 0Last Post: 12th Jul 2007, 17:16
