Hello,
I've been trying to encode a file to SVCD (with TMPGEnc), but it came with an odd framerate of 24.997 fps and every tima I try to convert it the sound gets out of sinc.
First, I'd like to highlight that the tools I have are VirtualDub and TMPGEnc
Things I've already tried:
- extract the audio with VirtualDUB to an uncompressed WAV and use TMPGEnc to encode it as usual (as described on one of the guides on this very site)
- encode viedo and audio in two different files and multiplex it later with MPEG tools on TMPGEnc
The audio allways gets desync.
I also have to split the movie so I can fit it into 2 SVCDs.
Could anyone here provide any hint on this subject?
Do you mean the source file has a fps of 24.997?
If so you need to do a proper framerate conversion. Search the forum and guides for info on Pal to NTSc conversion (or vice versa). The framerates may be different but the basic techniques will be the same. -
Try reading this post I wrote earlier, it might help.
https://www.videohelp.com/forum/viewtopic.php?t=161675
Good luck
Issues Converting from 25 fps to 29.97 fps
By Klagar in forum Video ConversionReplies: 7Last Post: 13th Jul 2011, 11:30 -
Converting 60 fps to 30 fps
By kelcey in forum EditingReplies: 11Last Post: 24th Jul 2008, 03:15 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 18:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 09:03
