Hi !!
I've a Panasonic SC-HT75 Home Cinema. This DVD player is able to play VCD. I try to play SVCD but some problems ocurs; Skip frames and sound. But there are two curious aspects:
- When I play the SVCD in double speed, the picture and sound it's almost perfect (a bite more speed then would be).
- If y press PAUSE, and next PLAY there are 3 o 4 seconds in which de picture speed is perfect but there isn't sound. After this time the screen becomes black and there is 1 econd with perfect sound. Finally the problem of skip frames/sound becomes again.
I try the VCD Header trick and the problem is the same.
AnyBody can help me explain why this problem??
Thnx.
