hello there
is there a program out there,one that can show DV movie on screen in real time while the feed is coming trough the card?
and so use the monitor as a TV screen , for the video ???
thnx
Yes Amcap can do this. See this link to get this freeware program:
http://noeld.com/dlvconf.htm -
10x that works fine!
but is there anything that can show the video feed in full-screen mode ?
thnx -
Amcap does that but you have to select "always on top" and "hide the menu bar" from the menu (under the Window tab); you must then enlarge the (almost full size) window frame (by dragging it with the mouse) and then you will get a full screen preview. You must press F11 to get out of this full screen mode.
You can also follow the instructions given:
I added a little feature that I was requested to toggle the caption, the menu, and the status bar on and off, so that only the video shows in the window. To toggle this option, just press the F11 key. While in the "no caption" mode, click the window frame and keep the left button down to drag the window. I also added F12 to toggle the "Always on top" state. -
You can also try this "TV Viewer" shareware program (it cost $10 to register it):
http://www.geocities.com/matroxfiles/tvviewer.html -
this TV Viewer progy kicks ass...
thanks a lot...
it does just what i was looking for
thanks
thanks
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Unable to view streaming URL in full screen theater mode Adobe 10
By badger1194 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Aug 2010, 22:12 -
How to view a divx movie full screen ?
By jedy in forum DVB / IPTVReplies: 4Last Post: 8th Apr 2009, 07:29 -
full screen high def video playback program
By syeager in forum LinuxReplies: 4Last Post: 11th Jun 2008, 10:39
