I have a very simple request. I want to take home movies of my kids and dump them into the computer via Firewire with my Canon ZR40. I want to burn them onto DVD's and have ZERO quality loss. I want the DVD to be playable in any consumer DVD player. What is the most practical software for this?
Up til this point I have used Adobe Premier to capture the video to an AVI and Sonic Foundry DVD Architecht to burn it to a dvd. It works, but sometimes the video seems to slow down for a split second. It's not terrible, but is there a flawless solution? Another thing to mention is that resulting avi file from Premier is HUGE....a 10 minute video is 2 or 3 Gigs.
Any suggestions? Thanks Travis
Have a look at Ulead's solutions.
I'm putting my family videos on DVD using both Ulead DVD MovieFactory 2 and Ulead DVD WORKSHOP:
http://www.ulead.com/dws/runme.htm
http://www.ulead.com/dmf/runme.htm
Jerry Jones
http://www.jonesgroup.net -
Not possible, not all players will play burned DVD'sOriginally Posted by tbarrnes
AVI files transfered from DV are large, that is just the way it is, around 1gig per 5 mins.
I don't know much about the software you are using so I cant really comment on that, but I use TMPGEnc to encode, DVD workshop to author to a disc image, and nero to burn, and I have no problems.
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 22:50 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 12:15 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 14:12
