I first started out with installing the svcd2dvdmpg1.1 and last night i bought the + version. i went to install it day and it says "Unable to install because a newer version of this product is already installed" why is it doing this and how can i correct it? thanks.
Thanks, DEvo
AnonymousGuest
You have to uninstall svcd2dvdmpg (1.1) from add/remove programs via the control panel. After this you should have no problems installing...
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
AnonymousGuest
There was no SVCD2DVDMPG in the add/remove in control panel. Don’t say look again because I have checked a couple of times thinking I would have just missed it. Then I went to windows explorer and deleted it form there and it still not working. After that I went looking for the registries. But I quit looking for them. Any reason it would not be in the add/remove folder? I just checked again to make sure I saw correct and it is not there.
Thanks, DEvo -
it would be under (s)vcd2dvdmpg... if not then let me know!
AnonymousGuest
thank you CB, I was not looking for it with the (S) i went straight to the S section. thanks for fast reply.
DEvo -
did you get it then?
AnonymousGuest
Yes I did. i have used the + version now as well and it works great thanks. just a side note. this is one of the only pieces of software i have bought so be proud. Great work.
MacBook 8GB upgrade problem - HELP!!!
By hasselblad in forum MacReplies: 5Last Post: 13th Sep 2011, 16:19 -
which upgrade would be best?
By DirtBikeMike in forum ComputerReplies: 24Last Post: 9th Feb 2010, 15:47 -
Many thanks for the upgrade
By guns1inger in forum FeedbackReplies: 2Last Post: 5th Feb 2010, 06:41 -
Philips DVP5980 upgrade problem
By snadge in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Feb 2009, 09:55 -
RE-Upgrade
By Casper_H in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 08:46
