Hi,
Its seems I get problems when playing Xvids on my Xbox, but it only happens with movies I have encoded myself.. not with Xvids I have d/l'ed.
So obviously its something im doing..
The problem I get is stuttering every 5 seconds or so,. and in some cases really bad chop.. and lots of dropped frames..
I use Autodub to do all my movies, and mostly I do 2 CD rips with AC3 audio..
The main difference ive noticed between my rips and the ones I d/l is that when I right click on the Xvid and click properties, them sumary, mine say 16bit Video Sample Size, and the ones I d/l say 24 Bit Video Sample Size.. But I cant work out where to change that ..
Anyway, anyone have any idea how to encode Xvids for smooth playback on an Xbox.. any specific settings etc.. As long as I can keep the quality really high
Thanks for any help !
Cheers.
i take it at the moment youre using xbox media player to play the files right?
i have found this to be the best method to play xvid/divx as the xbox somehow sends a signal to my amp that all films are dolby digital.
are you putting the film on cd-rw,dvd-r,dvd-rw cos most xbox's wont plat standard cd-r.
also the xbox is very fussy in the format used to record the disc. the latest versions of nero have an option for xbox compatibility, but i always use record now max.
i personally use dvd2svcd to encode my files to mpeg2 format and these work great on my xbox
if none of these work just ask again
feeky -
Yep, XB Media Player 2.4
I agree, Having a nice quality Xvid with the AC3 audio is great,. true DD 5.1 sound.. I love it !
Im putting them on CDR.. I have a Samsung Drive that reads CDR's perfectly..
Yes, thats something I should try is UDF File format, it might help.. But XB Media Player 2.4 has an ISO 9600 option, but Ill still try it.
Yea,, but can you get the DD5.1 audio from an Mpeg2 ?? -
a lot of the xvid files you find are about 700 mb total size, these normally have only mp3 audio (use gspot to check what audio a file has).
i have found the best way to convert these is using sonic foundry soft encode and convert to dolby digital 2.0 but with added surround so you get a really good quality pro logic signal. i have done some files this way and you can hardly tell its not 5.1
i dont think i can really help you much further because my method is putting onto dvd-r
have you tried just streaming files to your xbox using relax. that way you can just keep all files on your computer h/d and your xbox can play them fine. i put an extra 80 gig h/d in my pc for this purpose.
sorry couldnt help further
feeky
Black Magic Intensity Pro: Issue with xbox 360 settings
By dreamboss in forum Capturing and VCRReplies: 2Last Post: 14th Mar 2012, 20:50 -
What are best convert AVI settings for XBOX 360
By traveler31m in forum Video ConversionReplies: 5Last Post: 1st Mar 2010, 06:59 -
Changing NAT Settings On The XBOX 360
By Nitro89 in forum Off topicReplies: 0Last Post: 8th Nov 2008, 12:49 -
backing up and playing through xbox 360 on my tv
By Dalspaugh in forum Authoring (Blu-ray)Replies: 1Last Post: 5th Nov 2008, 15:45 -
Ashampoo - UDF Settings to make Disc readable on XBOX?
By snowbound in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2008, 15:58
