I used Premiere 6.5 MPEG encoder to send the timeline to SonicDVDit. Today, it's not working. Sonic says "File not MPEG-2 Compatible". It's worked many times before. What's going on?
13 minutes after your first post, and you're bitching about no response?Wow, no one can help me?
call Sonic's tech support and see if you get off hold within 13 minutes.
Are the files you're exporting from Premiere dvd-compliant mpeg files? And how picky is DVD-It about file formats and mpeg specs? I know there are various authoring programs that will not take some files, even if they are technically within dvd spec, because they don't measure up to the specs needed by the application.
Finally, what has changed on your pc recently? Have you installed or uninstalled anything? Have you changed some of your file attributes in your projects? If it worked before, and it's not working now, what's different?- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thanks to all for your ideas, but suddenly, it started working again. I don't know what happened.
Oh yeah, housepig, if you pay attention to detail you can see my reply for help wasn't 13 minutes, but 24 hours and 13 minutes. I hope the first part of your response made you feel superior being that you tried to make me look like an ass for being impatient. That's one of the problems of the world today, people always criticising each other, especially when it's non-constructive and/or unwarranted. (no hard feelings from me though)
Once again, thanks all!
Re using old Sonic hardware - little help?
By Pentos in forum Capturing and VCRReplies: 9Last Post: 17th Oct 2012, 11:34 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Sonic Vegas
By m baqar in forum Authoring (DVD)Replies: 9Last Post: 3rd Apr 2008, 05:29 -
Sonic Vegas
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 3rd Apr 2008, 01:11 -
sonic vegas
By m baqar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 2nd Apr 2008, 02:29
