I have been using Spruce up for about a year now using TMPG to encode at 352x480 and vbr between 2000 an 4000 without any problems. Now i have DVD Workshop and my first two burns have both had audio gaps (big ones approx 1 1/2 to 2 minutes).
Any suggestions on this?
By the way the "Finish" area in DWS plays the mpeg2 just fine audio perfect.
thanks
rg
What I do is skip the 3rd party encoder because there's no telling what such encoders really do to affect sync.
I use the Ulead MPEG.Now codec with the ADVANCED options activated:
To enable these options on a Windows 2000 or Windows XP computer, simply click MY COMPUTER>C: DRIVE>DOCUMENTS & SETTINGS>ALL USERS>APPLICATION DATA>ULEAD SYSTEMS FOLDER>ULEAD DVD WORKSHOP FOLDER>1.0 FOLDER>DVDWS (INI FILE).
Then add ADVANCE=1 under the [VIODRIVER] heading.
Save the change.
Then reboot.
When you open Ulead DVD Workshop afterward, you will be able to enter the DISC TEMPLATE OPTIONS and click a new ADVANCED button that appears under the COMPRESSION tab to access a new array of custom encoding parameter choices.
The Ulead MPEG.Now codec was developed by Ulead using the MainConcept SDK.
A zipped, PDF file explaining the settings in the ADVANCED encoding option is located here:
http://digitalvideo.8m.net/mc-adv-doc.zip
No audio sync issues here.
Jerry Jones
http://www.jonesgroup.net -
So, are you telling me that it's a codec problem? this beautiful avi for RELOADED from Sharereactor is perfect when authored with Spruce so it's not the mpeg (it's Workshop) ... should I try DVD LAB instead?
or any other suggestions?
thanks
Tony
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
