  1. Anonymous
    Guest
    Hi im having a couple of problems with svcd2dvdmpg+ hope someone can help me
    First when i try to use the program starting with bin and cue files the prog just says ripping then dosnt do anything. when i originally used the non plus version i didnt have this problem at first but then all of a sudden i did. However it works fine if use vcd gear to extract the mpg its just a bit of a pain.
    Second problem is when i choose the author mode the prog gets stuck on the multiplexing part and just stays like that. It works fine when i just create the m2v & mpa files to use in my authoring program but i would like to be able to get the program to do that for me.
    I am using Besweet ver 1.5b18
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you get me a sample as per my the FAQ on my site?
    Does the "sticking at multiplexing" happen for all your attempts?
    If the ripping fails then that usually means the mpegs are dodgy - i think if you could send me a sample i can tell for sure.
    CB
