Strange this one :
When I encode using MainConcept MPEG Encoder 1.3.1, my output video is created using separate video/audio, but the video always comes out way to 'blue'
Best way to describe it, is as if someone has turned the blue level all the way up, I've uninstalled, cleared anything relating to the encoder out of the sytem/registry/etc, reinstalled, still does it
Is this down to some filter/codec ?
No video settings are touched in the encoder, just alter the CBR rate, and set it up for DVD output, and thats basically it. I don't touch any of the advanced video settings, mainly 'cos I'm not sure what they do !!
I have the Ace Codec pack installed, latest version, apart from thsi annoying problem, I have nothing else going wrong
Thanks for any help
Basically ANY .avi from the 'net ...........
Now, th annoying thing is, I've used the exact same encoder, with very good results to convert movies to MPG so I can burn them before, but now its doing this 'blue' thing
If I use CCE to convert then the same movie comes out OK, but CCE leaves a border around the output file, whereas MainConcept fills the whole screen, espcially converting from 16:9 to 4:3, so I'd much prefer to use MainConcept
I've tried TMPGenc, but it constantly moans about file errors, or just falls over on some files, where, again, once I understood how to get MainConcept to accept movie files properly, using separate audio files, then MainConcept was perfect
Just this damn annoying too much blue issue -
any avi would mean about 50 different avi formats ,...
so that was no use ..
anyway .. in options (import mod.) you will see 1 or two direct show filters and 1 avi ... disable the avi and try again ...
if no go - turn on avi and shut 1 at a time each of the direct show ..
ussually its disabling avi that works -
Well, for the moment, it seems to have cured itself, again
Didn't do much either, have another try -
Yep,
You're right, down to the AVI import module, disabled, no more 'too blue'
rip blue ray and watch it on computer (no encoding)
By chadkan in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Dec 2011, 04:59 -
MainConcept H.264 frame rate issues encoding Final Cut output
By soandso in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 12:46 -
Blue-ray re-encoding, how do you do it?
By herbapou in forum Blu-ray RippingReplies: 7Last Post: 16th Apr 2009, 20:07 -
Mainconcept encoding problem - Audio
By Mysteriouskk in forum Video ConversionReplies: 0Last Post: 25th Nov 2007, 09:25 -
Encoding 720p MJPEG file using Mainconcept encoder --> for Streaming vid
By Mysteriouskk in forum Video ConversionReplies: 3Last Post: 25th Nov 2007, 03:39
