DIVX is soooo crap, nothing is ever straight forward with it![]()
I am trying to convert an xVID AVI file in TMPGEnc to an xVCD MPEG file. I have all the settings right, I have extracted the audio separately and I am joining the two together. However, I start to encode it and I get the following message:
Doe anyone know what this is and how I can correct it? Its very annoying.
Thanks.
I've had a similar problem (I think).
I had to used VirtualDub to recode it and that worked for me.
I think it was due to bad frames and the codec having a big in it. -
Or try frame-serving using Virtualdub.....or look up my old (?) guide using Panasonic encoder to encode to (x)vcd. But eeehhh... i started making vcd's too in the beginning..... why not make svcd? Takes a bit more time to do...... but the quality is much better.
D.C.
" Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon. -
How do I do this? And if it has bad frames, how do I correct them? This is my first time trying to do anything with DIVX succesfully.Originally Posted by bizeebee
Come on..... search the forums & guides a little bit, ok? Here's my easy-way to do vcd:
https://www.videohelp.com/forum/userguides/144340.php
But right now... maybe already a bit outdated. When this doesn't help you..... search for the guides about frame serving. Let me know if it works for you, good luck.
D.C.
Encoding Xvid in 50mbps?
By 24fps in forum Video ConversionReplies: 11Last Post: 15th Aug 2011, 20:37 -
Xvid encoding
By fester77 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2011, 08:19 -
Quick XViD Encoding?
By shorto in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2008, 04:54 -
Encoding with Xvid.
By Felo in forum Video ConversionReplies: 1Last Post: 26th Aug 2007, 01:38 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 05:42
