i have converted Divx to VCD PAL and i have a slight (2sec) unsynch
betwen yje audio and video how can i fix that?
second, can i just rip the sound track from the VCD and from the original Divx and replace them? it should work with good synch?
Try extracting the audio using Virtualdub then use the resulting WAV as the audio source in TMPGEnc
"Today is only yesterdays tomorrow"
My fraps audio and video is out of sync. How do I fix it?
By dxdiag in forum Capturing and VCRReplies: 3Last Post: 21st Dec 2010, 21:53 -
Audio Damaged After Video Conversion. How to Fix?
By Fluoresce in forum AudioReplies: 1Last Post: 5th Aug 2008, 03:01 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 10:07 -
Can I fix a VCD?
By Haopengyou in forum Authoring (VCD/SVCD)Replies: 6Last Post: 1st Feb 2008, 00:26 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
