I downloaded the latest encoder for Premiere and it does not work (I also tried 1.2).
This is what I did and the exact problem that I ran into.
-I uninstalled the encoder that came with Premiere.
-I then installed the 1.3 version encoder. It asked for the location of the premiere.exe file, so I pointed it to the file.
-I then rebooted and opened Premiere and encoded something that I was working on. It extracted with no errors.
-I then went to play the video file and I got an error that said I needed the following file..."mplvpx.dll"
-I downloaded it off the net, put it in the windows/system directory and now I went to play the m2v file. I did not get an error but it just showed a black screen with a red "X".
Anyone see this before? How can I fix this so I can use the latest encoder?
Thanks!
-Machine
Are you able to play *other* m2v files successfully? I'd sure check that first before I'd blame the encoder. Also, MainConcept doesn't produce DVD compliant PCM files -- so if you are encoding to separate streams you need to reprocess the audio (I use BeSweet to change it to AC3, but you could just as easily reencode it to compliant PCM).
Finally, you might want to get on the Adobe MainConcept forum and ask this question -- I'll bet you they'll have an answer for you post haste (the MC boys frequent and respond daily to questions/problems)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
My computer does play other m2v files.
I never reprocess the audio stream. I have burnt many DVD's with the file from the Premiere Encoder. what is the problem with that?
I will try the other forums.
-Machine
Adobe Premiere - MainConcept's H.264 vs x264 open source encoder
By rallymax in forum EditingReplies: 159Last Post: 19th Jun 2012, 20:51 -
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 19:51 -
My 2 problems with Adobe Premiere
By IT learner in forum EditingReplies: 2Last Post: 16th Sep 2011, 09:46 -
Quality problems on Adobe Premiere Elements 9
By inimitable in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2011, 06:56 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17
