ok here goes...
I followed the instructions last week and converted a svcd succesfuly using the instructions exept for repatching to 480 for svcd2dvdmpg to unlead dvd2.. great sound and video.. this week using the same instructions same trial and now i get video and no sound.. i attempted to create to video_ts but after patching the video is gone!!
also another issue is that after i convert with svcd2dvdmpg and add video to unlead it changes 2 svcd's at about 500 mg to over 5 g.. please let me know what i am doing wrong!!
Your "other issue" sounds a lot like ULead is resampling the movie to 720x480. I've had a 2-disc SVCD become like 6GB once TMPGEnc was done upsizing it.
There has GOT to be a better encoder. I hear that CinemaCraft is good, but it's both expensive and absurdly difficult to use - apparently they spend all their time tweaking algorithms and none whatsoever writing a workable UI.
- Gurm -
AnonymousGuest
thanx man i'll check it out.. you knwo i did change the quality to best over "good" so maybe thats where it went wrong????
I guess i'll look into CinemaCraft although i am very green at this and if i can't handle these 2 then... i'll look into it though thanx.. read read and read some more... test test and test!!! -
Have a look back through this forum... and the DVD authoring one. Someone mentioned another (now discontinued or hard-to-get) encoder that was about 100 times faster than TMPGEnc.
- Gurm
Does this sound like a MOBO issue?
By beavereater in forum ComputerReplies: 9Last Post: 7th Feb 2012, 06:59 -
DVP5992 Philips sound issue
By udidwht in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Nov 2010, 21:58 -
Help with a sound issue on a Toshiba SD-6100
By hhcup in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Apr 2008, 09:06 -
vob2mpg sound issue with certain DVDs
By YoKnows in forum DVD RippingReplies: 1Last Post: 31st Jul 2007, 19:10 -
Sound Issue
By NightFire in forum RestorationReplies: 5Last Post: 26th Jun 2007, 18:15
ok here goes...
