I'm haveing a problem with the authoring step. I get all the files to de multiplex, convert to 48khz audio ok, multiplexes the streams back together ok, but just sits there at that point. The program does not create the VIDEO_TS folder or the ifo bup and vob files that are supposed to be in it. Is there a program besides BeSweet that needs to be in the svcd2dvdmpg+ folder? Any help would be appreciated, I can author with another program, but I bought svcd2dvdmpg+ so I wouldn't have to go thru all those extra steps![]()
Results 1 to 12 of 12
What version of BeSweet are you using?
BeSweet v1.4 and I do have the MS.net framework 1.1 installed, but, like I said , I'm not having a problem with conversion , but with the authoring step.
Sorry, didn't mean to snap. Like my handle says. I'm an old man. I'm Crotchity.
Indeed yf2001usa is correct.
From the sticky thread on this forum:
NB you need beta 1.5b17 or above. If you use version 1.4 SVCD2DVDMPG+ will not work.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
couldn't resist....Like my handle says. I'm an old man.
Good luck with it.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Well i think you should upgrade your download Chrissyboy, cause i dloaded from your site 2 days ago and mine has bsweet 1.4
Thats the freeware version. BeSweet 1.4 is included in that 'download'
The plus version requires the latest beta (1.5b17 or greater)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ok uhh... I still have one teeeeeeny problem.
When mplex.exe is running and it gets to the end of multiplexing an mpeg part. (like title1.mpg, title2.mpg, etc.)it gets to the part that says;
INFO: [mplex] Video e0: buf = 237658 Frame = 000000 Sector = 000000
INFO:[mplex] Audio c0: buf = 4096 Frame = 000000 Sector = 000000
At this point everything just stops,and sits there, and sits there, etc.
Only if I click on the exit box at the upper right of the window does it move on to the next part or if on the last part, the dvd folder process.
Is this supposed to happen? I thought I understood it to be an automatic process without the need for my intervention. Was I mistaken in this understanding? and if not what am I doing wrong now?
(ps this is after I upgraded BeSweet to 1.5b.18 ) -
It is automated - you just need to let it do its thing. Are you giving it long enough? do you notice cpu/hd activity?
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
