how do i do this
i tried multiplexing the streams but it just wouldn't work when i try playin(on karaoke(dvd,vcd,ld capabilities) machine)
Did you multilpex using bbMPEG?
Also when you multiplex two audio streams, in order to play the 2nd (other) stream, you press the Audio button your DVD Remote.. if it has one.. thats how it works for me. -
wut do u mean? are you taking a karaoke source from a dvd or another vcd? explain more in details
For a VCD you'll have to make one left and the right channel. For a SVCD you can just mux the video and multiple audio streams w/ bbMPEG. If you make a SVCD w/ multiple audio streams, then hitting 'audio' on your remote will change them.
For the VCD you'd need to select only left or right channel to play. -
The source is DVD. I multiplexed using TMPGenc. I also tried multiplexing with one stream in the right and another in the left, but it still didn't work. Maybe I did it wrong. I'm trying to make a vcd out of it. I have no problem with the video it's just the audio. I can only hear one stream, i tried switching but it didn't work.
How to make a karaoke video from A to Z
By Swtess in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2011, 21:29 -
How to make a karaoke VOB file from 2 (one audio and one text)?
By coxanhvn in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2010, 01:57 -
How Do I Make A Karaoke CD
By slayer_of_all in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2009, 11:58 -
How to make karaoke help
By Holi-chan in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jun 2009, 08:27 -
how to make the audio of DVD karaoke louder
By edong in forum Authoring (DVD)Replies: 2Last Post: 20th Oct 2007, 16:23
