  1. YAN
    Guest
    Hello all
    I've followed all instructions in installing ffmpegX and required components and installation has gone well.
    As a test I am trying to convert a VOB file into a VCD compatible format and get the following error:
    Last login: Mon Jun 9 21:20:01 on ttyp1
    Welcome to Darwin!
    pbpaste | sh
    [Nicholas-Yannioss-Computer:~] nicholas% pbpaste | sh
    Encoding started on Mon Jun 9 21:20:03 EST 2003
    ## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
    usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
    example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
    example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
    **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
    Other conversions (that don't use mpeg2enc) seem to work.
    Can anyone give any assistance.
    Thanks!
    Make sure there are no spaces in your path/file names. If you've got a name like "My Movie" the OS (which is Unix-based) will look for two files..."My" and "Movie".
