For some reason, tmpgenc won't open up a mpeg2 file that it just encoded. It used to. Keeps giving me can not open or not supported. Any idea's? Mpeg works fine though. I use the standard svcd template, changing nothing.
Well now I can't open a .d2v file from dvd2avi. Getting same error. Have the vfapi plugin.
I'M HAVING THE SAME PROBLEM.I CAPTURED WITH DAZZLE 2,10000
KBS AND TMPEG WON'T OPEN IT.IT WON'T OPEN ANY MPEG2 FILES.ANYBODY HAVE ANY IDEAS? -
install the mpeg2 codec into your system....i would suspect that it encoded to mpeg2 because that ability is built into tmpgenc, but your "system" does not have the capability to handle or play mpeg2 without the necessary codec installed
Where can I get a mpeg2 codec? If it's on this site, I have no idea which one it is.
You can also get the MPEG-2 Codec by installing a Software DVD Player like PowerDVD or WinDVD.
Also, make sure your 30-Day Period for MPEG-2 Encoding in TMPGEnc has not expired. =|
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
