Sorry if this has been covered elsewhere, I have searched to no avail.
I am using DVD Decrypter V3.1.6.0., DVD Shrink V2.0, Bilkpaq 4X gen 4 disc, Pioneer 105 DVD writer.
I have just tried to back up Reign of Fire, everything works fine except the menus. All you can see on the menu is the line that underlines the options on the menu but nothing else. Everything else is black. You can still select menu options but its pot luck which option you select because you canot see the menu. Everything else about the disk works fine.
I have backed up same disk with DVD2one with no problems whatsoever.
This happened once before with the previous version of DVD Shrink using a different writer and bulkpaq 1x gen 3 discs.
I don't thinks it the media since after more than one hundred backups with DVD2one using bulkpaq I have only made 2 coasters. I might be wrong though.
Is it a bug in DVD Shrink?
Cheers for any response.
I think the problem solve if you do compression at Full Dish, if you do compression at Re-author it will ignore your menu.
Let me know if your problem is solved.
Yeah that sounds like the problem, your doing movie only instead of full disc. Also get DVD Shrink 2.3, 2.0 is/was really beta software and had some bugs.
Not tried Re-Author but have tried Version 2.3 and it now works fine.
Thanks for all your help.
How to do a dvd shrink containing only the movie without menu's etc
By vain in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2009, 08:57 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 10:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 07:20 -
Blade Runner Briefcase Dangerous Days (Disc 2) menu problems after shrink
By jrshull in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 12:49 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 11:07
