The title pretty much says it all. I've done a lot of searching here, but I can't find any straightforward explanation. If anyone has had any success burning a NTSC DVD from a PAL source, I would love to hear about it.
Thanks.
Guest
Guest
I'm the author and I apologize I didn't add a '?' to the title. As far as I can tell I can't edit it....
Da GuruGuest
I've converted a number of NTSC DVDs into Pal DVDs relatively easy using tmpgenc. Cannot see that the same workflow wouldn't work equally well in reverse.
- Run DVD2AVI on the ripped movie to create a d2v-file.
- Feed that into tmpgenc and adjust size and frame rate.
- The sound usually gets a bit out of sync but a couple of tries using AC3Machine's delay setting and BeSweet usually takes care of that problem
Hope this helps!
Guest
Well I'm running Mac OS X so unfortunately that solution doesn't work for me. Thanks though.
Any 'X' users know how to successfully convert a backed up PAL DVD to NTSC?
Guest
I've only been on this forum for 10 secs so not sure if a full response is warranted.
It can be done. Doing it well is hard and requires a bunch of tools and commercial progs.
If you can't find what you want anywhere else, drop me a note:
obfuscated optusnet com au
(fill in the gaps
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 20:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
Convert a CSS Encrypted PAL VIDEO_TS folder to NTSC DVD with subtitles
By Lord Stinkfoot in forum MacReplies: 6Last Post: 25th Oct 2007, 19:35
