  1. Member Mark_Venture's Avatar
    Mar 2003
    Delaware, USA
    I have a DVD that I can rip all but one VOB file. There is one set.. VTS_02_0.VOB, VTS_02_1.VOB, VTS_02_2.VOB, VTS_02_4.VOB, VTS_02_5.VOB and VTS_02_6.VOB are ok, but VTS_02_3.VOB is zero K. Because of this, Instant copy can not resize it to fix on 1 DVD.
    The entire DVD was ripped to hard drive, and PowerDVD can play what is there as if it was all there (except missing scenes). The menus, languages, extra features, etc. all work when playing back with PowerDVD.
    Is there any way to fix this so it can be recompressed with Instant Copy to fit to one DVD+R disc? (And yes I know some scenes will be missing.)
  2. ifoedit to create new ifos.
    then use IC or dvd2one
  3. Member Mark_Venture's Avatar
    Mar 2003
    Delaware, USA
    I did try ifoedit. Not knowing how to use it, I looked through the guides on this site at the various ones that use it. I tried to "learn" from them what I needed to do but I must have done something wrong, because trying the resulting IFO and VOB files did not work in PowerDVD.
    Is there a guide for dummies on how to do this some place?
  4. The IFOEdit guides written by Derrow (IFOEdit author) can be found here:
    http://mpucoder.kewlhair.com/Derrow/index.html
    08.27.02 - IfoEdit guides are available again, for offline reading.Download here. This time they're on a different server. Thanx goes to Sven.
