I am trying to encode from AVI to MPEG1 w/ "TMPGEnc12h". I also downloaded "MPEG properties" to check if my MPEG was compliant. I have encoded an AVI several times and checked it with the MPEG Properties utility and everything looked alright. "Alright" defined as all the levels displayed i.e.( System, Video, and Audio ) were at the video CD level mark. Next I attempted to burn with Nero 5.5 ( w/ the video 2.0 check enabled ) and ran into no problems. However, when I tried to play the VCD on my player the Hitachi DV-P305 (which says on the front that it plays Video CD's )it gives the message "no disc".
Is this an encoding problem, Nero problem, or Hitachi problem? Or maybe just a little operator fault? Am I reading the MPEG properties utilities right? All questions I would love to know the answers to. Thanks in advance for any replies.
If you check the "DVD PLayer compatibility list" you'll find that your Hitachi unfortunately doesn't take CD-R's, and apparently will only take black layered CD-RW's.
Checkout the comments:
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=96&Search=Search&list=0
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-07 16:03:22 ]</font>
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 19:06 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 10:37 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 19:00 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 15:35
