I know if you backup a DVD with DVDXCOPY you can not make another backup copy from the copy. My first question is can we do that with DVD2ONE? Second question is can I use DVD2ONE to backup a DVDXCOPY copy?
Regards
"My first question is can we do that with DVD2ONE?"
YES
"Second question is can I use DVD2ONE to backup a DVDXCOPY copy?"
I don't know because I've never used DVDXCopy before. I suggest you try to rip it with DVD Deccryptor. If it rips okay, then you can probably do anything you want with it. -
Just one additional note. The copies you get with DVD2One, you can duplicate them using Nero's CD Copy from it's File menu.
Thanks for the info. I only have DVDXCOPY and was hoping someone who owns both could tip me.
Regards
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
