could some1 give a run down from top 2 bottom on this. im trying 2 make a motion menu with this but i dont really know were 2 start as the motion option isnt highlighted and i dont know how 2 start it off plz help me plz
Step-by-step tutorial for animated menu background:
http://www.ulead.com/learning/dws/dws_01_1.htm
Step-by-step tutorial for animated buttons:
http://www.ulead.com/learning/dws/dws_02_1.htm
Additional tutorials:
http://www.ulead.com/learning/dws.htm
Book:
http://www.ulead.com/partner/learntool/dwsbook/runme.htm
Jerry Jones
http://www.jonesgroup.net -
I had this lil problem when i tried a vcd but if you are choozin DVD it should not be greyed out.
Tony -
If your using the Demo version, I'm pretty sure you can't use a motion background. You need the full version.
Could this be it?
